1 - 8 of 8 Posts
My 06 Exige is equipped with Lotus Traction Control (T/C).
The other day, I tried to press T/C button on the shifter column but
T/C telltale indicator in the instrumental panel didn't come on.
I pressed the button nearly one minutes.
Does my T/C cannot be turned off? or is it already off?
I searched the forum and someone suggested if the button is
disconnected, T/C feature automatically deleted in the ECU
program. And only Lotus dealer can fix the situation by reflashing
the ECU or something.
But as far as I remember, I never disconnect the button.
Any advice?
The TC should light after about 20 seconds. A reflash usually won't fix it, if it is disabled it may have to go to lotus hq or be seen by the factory rep.
Charlie,
Thanks for your comment.
Does that mean my T/C is disabled and cannot be enabled
without getting help from Lotus cars?
Originally I was intended to disable it for AutoX then found
button didn't work.
This might sound like a stupid question, but you're pressing and holding down the button while you're stopped with the engine running, right?
It works while your moving as well. I do it at the track all the time when I forget to turn it off. I think it has to be held down for 5 seconds to de-activate traction control.
:up:
Good to know... I've always disabled it while stopped.
1 - 8 of 8 Posts
