Just in the last few days when my tach reaches around 6200 it sticks. The engine continues to increase in rpm. Tell tale light does not iluminate. No rev limit. After I shift the tach either stays at or below 2000 AND REMAINS COMPLETELY OUT OF CALIBRATION ???
At Idle tach is at 0. If I turn the ignition off it resets and works fine. I have tried the Owners manual "door open.. " method. But the problem continues. I also have searched the threads but have not come across the same situation.
If anyone can point me to a post with this situation or might be of some help it would be deeply appreciated. Btw.. ambient air temp has been between 25 to 30 degrees when this occurs.
Hopefully I wont get bombarded with :tadts:
Thanks!
Thanks!
