So I just bought an elise yesterday and one of the problems the dealer said it has was the tachometer and cluster working off and on. Even if the car is on and running the tachometer and rpm Gauge will read 0 and the fuel will say empty. But if you tap the front of the cluster it jumps to where is suppose to as far as the speed your going and rpm, then drop down to 0 even going 75 on the freeway. Does anyone know how to fix this problem or have had a similar experience. The dealer said they called lotus about it and it's on order but it may take 2 months to get it in since Lotus doesn't troubleshoot it, they replace it. I'm not a wiring guru but if it's as easy as a fuse that would be awesome.
