A strange starting problem has appeared... '07 Exige S...
I've done all of the usual checks: battery is good, connections are good, grounds between engine and chassis are good, etc.
Here is what happens: I turn the key to the on position, press the keyfob button to disable the alarm... fuel pump primes for a few seconds... when I press the start button, I hear a solid "click" from the engine bay (seems to be the starter solenoid)... then nothing. No starter groan, nothing but one solid click.
Since the fuel pump is working, doesn't appear to be the immobilizer or the inertia switch. Since the solenoid is working, doesn't appear to be the immobilizer.
Pulled the multi function relay unit... is there any way to test it for obvious faults?
Any other thoughts? I have researched this thoroughly here on LT for the usual suspects.
The battery voltage only drops to about 12.4 volts when I push the start button. I've tried two different batteries, even jumped the battery with another car.
