Component: hard top panel
Problem: bumper pad worn or missing
Symptoms: loud rap or bang when car hits bumps
There are many places that the hard top can make noise. One that isn't immediately obvious is the rubber bumper pad located at the rear latch block. (See photo). If yours are worn or missing, the hard top will tap against the latch block and cause wear and noise. Lotus has a replacement kit.
i suspect he means that lotus has a replacement kit .....:shrug:What do you means by '' Lotus has a replacement Kit '' ???
I'm having a big bang rattle when I hit bump right behind over my head. I was sure it was the trunk ( engine cover ) shaking but now with this thread I'm thinking it could be the hard top roof my problem...
What should I do to check it ?
Component: driver's-side seat rails
Problem: seat rails have been installed improperly
Symptoms: driver's seat has slight forward / rearward "play", clunk under braking or acceleration
((Photos to follow))
I fixed the annoying plastic-on-plastic creak from my hardtop as follows:What do you means by '' Lotus has a replacement Kit '' ???
Any thoughts? The sill noise is a creaking/swooshing sound, if that makes any sense... Do you all have luck with this stuff at the dealer?I have an increasingly annoying "noise" coming from under the driver's side doorsill. Hard to explain the sound - kind of like a swooshing sound. Anyone have this? Any idea what that could be? In addition to dashboard squeak and something from above/behind the passenger seat...
Do you guys have luck with the dealer fixing squeaks/rattles/other noises? My Elise is still under warranty... But I know that these things are part of the endearing qualities of owning a Lotus and have heard as much from the dealer.
How much torque do you use for refitting the shear panel?Next, unbolt the "U"-bracket that secures the shift linkage to the shear panel.
Here is a photo of the shear panel as seen from under the car:
And a photo of the car without the shear panel in place (never operate the car w/o the shear panel in place and properly torqued.)
Pop off rear diffuser, check tightness of heat shields, then check the bracket bracing the exhaust manifold, it might have snapped.Time to revive this thread...
I'm getting a horrible rattle from the Elise exhaust area at idle. It goes away at higher RPMs. It's worse when the car has just been started. Sounds like a loose shield, but I hoping it's not something internal in the exhaust.
Any ideas??
Im planning a fuel-tank exchange later this summer and i cat seem to find this data.
