I believe it is also illegal, at least here.Bose Noise Cancelling headphones make long drives much more enjoyable. Even with the top off. Really knocks down the noise of tires on other vehicles.
The foam block you mentioned is fairly hard and does not do a good job of damping out the glass movement when riding over bumps. Even with the guide rail screws tightened, I still had a horrible rattle of the driver’s window over bumps when it was in the full down position. I fixed it by sticking a 1/2 inch thick layer of foam weather strip to the top of the block and then building two more duplicate blocks with foam and RTV'ing them to the bottom of the door. Now when the window is down, it rests on three soft stops that damp glass movement over bumps.Component: door window nylon guide blocks
Location: inside door, between glass and the guide channel
Problem: "play" between the window nylon guide blocks and the guide channel
Symptoms: clunk under braking, acceleration, and bumps in road
I'll be adding to this as I get time... but in a nutshell, if you can move your door windows forward and back, check your front and rear nylon guide blocks. You will need to remove the door panel to check this. The guide blocks are white plastic (nylon) parts that are epoxied to the leading and trailing edges of your door windows (2 in front, 2 in back) and engage the steel guide channel (1 front, 1 rear.)
My passenger door window was making a h*ll of a racket whenever the car went over a bump in the road. After disassembling the passenger door, I found that the rear guide blocks were about 1/8" to 1/4" away from the window guide channel: this allowed the window to move forward and rearward and make a "clunk" each time it did.
Solution: I put self-adhesive heavy-duty felt pads on the two rear guide blocks. This fills the gap and prevents the window from moving fore and aft. I will revisit this later to find a more permanent solution.
Note: this does not appear to be a "wear" issue, it appears to be "slop" from the factory.
ALSO: there is a hard foam block glued to the bottom of each of your composite doors. The window, when fully lowered, should rest against this foam block. If your window is rattling and banging when you hit bumps (when the window is lowered), you may want to check to make sure that the foam block has not become undone.
Thread dedicated to that problem with the best grease I could find for the seat rails:When driving slowly with the wife in my 2005 Lotus Elise, there was this tick-tick noise when decelerating and accelerating, like a coin rolling back and forth someplace behind the passenger area. When I was by myself, I rarely heard it.
Took both seats out and found the culprit - the ball bearings on the driver's seat were dry and one or more of the balls were rolling back and forth. Put some lithium grease on the rail and spread it around. No more noise. Turns out I did not need to take the driver's seat out for that.
Just tried tackling this one over the weekend. Definitely confirmed this is where my rattles are coming from (even my undertray rattles when I tap it). Few questions:Component: shear panel
Problem: bolts may loosen, shear panel may warp, shear panel may be deformed by improper jacking
Symptoms: metallic buzz at certain RPM, emanating from under / rear of car
This thread has good information:
Need Help with Shear Panel Re-torque - LotusTalk - The Lotus Cars Community
First, remove the belly pan and set aside. Use your fist to gently rap on the shear panel, and what you hear may surprise you.
Next, unbolt the "U"-bracket that secures the shift linkage to the shear panel.
Here is a photo of the shear panel as seen from under the car:
And a photo of the car without the shear panel in place (never operate the car w/o the shear panel in place and properly torqued.)
The shear panel can be completely removed by carefully sliding it in between the emergency-brake cables toward one side of the car. Make sure your wheels are chocked, then release the emergency-brake to slacken the cables. It is still a tight fit, take your time and you will be able to wiggle it out. Be careful not to cut the emergency-brake cables with the sharp edge of the shear panel.
Once removed, check the panel for flatness. Any bulges or bends will increase the noise it produces: the gas tank straps are only a few millimeters away from the shear panel: they can contact and clatter.
Here is a photo of the shear panel removed from the car:
In addition to removing, reinstalling and re-torquing, I took the opportunity to apply some Dynamat sound deadening material. Dynamat XTREME
**I'll edit this later to add details of removal, re-torquing, etc.**
Before you re-install the belly pan, go around the shear panel and rap on it gently with your fist. Pay attention to the shift linkage cables: mine were making a loud snap. I was able to use a small (1" x 1") piece of Dynamat (just in front of the "U" bracket) to isolate them from slapping into the shear panel.
Hi Guys,
I had a friend test drive my lotus this week. when he came back there was a squeak coming from the front left suspension... i asked him if he bottomed out or something, he says no. I believe him. He says that it started after he stopped to put fuel in.
If i press on the front left of the car.. it squeaks, so its not engine related.
Anyhow, any idea what could cause this... its really... really annoying.
any help would be greatly appreciated.
cheers
How many miles on your car?Hi Guys,
cheers
