This rough and ready development car means a lot to Lotus. Six months from now, the production Series 2 Exige will be unveiled at the Geneva show. It will glint and gleam, it’s fastback-styling will attract comment, but what everyone will be wondering is how it goes with the 190bhp Toyota 1.8-litre VVTLi under it’s engine cover. Since it’s launch in 1996, the Elise has been powered by many iterations of the Rover K-series, the most potent of them installed in the back of the S1 Exige, so this is a big change for Lotus. And it’s bigger than the Exige, because the Toyota engine will also power the up-coming North American-spec Elise.
Our presence at Hethel to drive the first prototype so far ahead of the launch is mutually beneficial; we get to drive the new engine and tell you, potential Lotus customers, what we think of it, and Lotus gets early feedback on what is a significant engineering change.
Our opinion of the VVTLi engine in Toyotas is well documented and regular readers will know that it isn’t one of our favourites. In our first drive of the Celica 190VVTLi (now T-Sport) we wrote ‘to get the most from it, you have to drive it like you’re trying to blow the thing to pieces’. When we tried it in the heavier, soggy Corolla we were less kind. In short, it was dire - it seemed to have very little torque and even when you got it into the power band between 6000 and 8000 rpm, the gear ratios made it infuriatingly hard to keep there.
‘The Celica and Corolla are much heavier cars than the Exige and therefore the lack of torque isn’t so apparent,’ points out Exige S2 project engineer Geoff Grose. He says that pulling from low revs, the Toyota-engined Exige is as fast as the Elise 111S with the 156bhp K-series VVC engine, with a real shove on top when the high-lift, long-duration valve timing kicks in. ‘It’s like having two engines in one.’ He states.
We’ll soon see for ourselves, but why change at all? The K-series is a very good little engine; compact, remarkably light and British too, all positive factors for a lightweight British sports car. ‘It will continue to be used in European Elises for the foreseeable future,’ says Grose, ‘but it’s expensive to make in 190bhp trim. For the US Elise we wanted an exciting performance and the VVTLi engine gives us that with the refinement when you’re not stretching it. Also, Toyota has a very good reputation in the US.’
The hunt for the right engine has been going on for a few years. In it’s consultancy role, Lotus Engineering has designed 10 per cent of the engines that power all new cars sold in Europe, so it has a very good picture of what’s out there/ ‘We certainly punch above our weight in engine expertise,’ says Grose. ‘The basic parameters set for the engine were that it must be four-cylinder, sub-2-litre and have an output around 200bhp or more. So much less wouldn’t do.’
A turbo unit was ruled out, partly because Lotus has an agreement with GM, for whom it produces the Vauxhall VX220 Turbo, not to have overlapping models, but also because the character of small Lotuses is better suited to normal aspiration. By a process of elimination that left two engines in the frame – the Honda VTEC and the Toyota VVTLi – and Toyota and Lotus have historical links dating back to the early ‘80s when the Japanese company had a small shareholding in Lotus.
The Honda VTEC is better known but the Toyota engine is sophisticated in a similar manner, having variable valve timing (VVT) and lift (Li). Installed in the Corolla and the Celica T-Sport it produces 189bhp at 7800rpm and 133lb-ft at 6800rpm. It also comes with a six-speed manual.
‘Toyota was a co-operative partner,’ says Grose. ‘It’s not simply a case of bolting in the engine, complete from air filter to tailpipe. We wanted to put in our expertise as well, to create our own management system to integrate the engine into our package, to fine-tune it’s responses to suit our lighter car.’ There will be no drastic change in outputs, but the character of the engine is said to be appreciably different.
