...hah!..
If you bring the Chasecams, I'll bring the HRMIt is amazing how elevated the heart can get in 60 seconds. I would like to see my heart rate at a track vs at an autocross.
Autocrossing was what put me in the hospital as my heart was not working right on each run. At the end of the run I could not breath or talk. Going to the hospital saved my life.
Autocross probably isn't good for you, but it probably isn't bad either.
A high pulse alone isn't going to do much for your health, unless it is in conjunction with some exercise. Good cardio is getting your pulse up for at least 20 minutes while running, etc.
Next time you should put it on some out of shape sucka like me. I'll bet my heart rate doesn't nearly come down as fast as Alex's.
BTW any postings of the times from the autox?
Merging the DL1/traqmate with the Polar will require a little bit of coding skill. This is because the data aquisition systems generally record at 5-10-20 Hz while HRMs are usually every 1-5 seconds. You are going to have to write something to sync both data files such that the HRM data gets mapped to N different data log readings - its easy to do but still does take some work.Now you've got me tempted to wear my Polar heart rate sensor and watch for the next LCS event... I'll put an extra gauge on my DashWare dash...![]()
Have you ever seen this thread: http://www.lotustalk.com/forums/f157/2007-exige-s-intercooler-air-flow-study-59117/?Merging the DL1/traqmate with the Polar will require a little bit of coding skill. This is because the data aquisition systems generally record at 5-10-20 Hz while HRMs are usually every 1-5 seconds. You are going to have to write something to sync both data files such that the HRM data gets mapped to N different data log readings - its easy to do but still does take some work.
I have a rough version of the script now but it isnt ready for public use yet. Hopefully I'll be able to write and release a freeware version once I get some spare time after the Buttonwillow Lemons race (mid aug).
In that case you should write the script and I'll just use yours insteadHave you ever seen this thread: http://www.lotustalk.com/forums/f157/2007-exige-s-intercooler-air-flow-study-59117/?
I had to merge the data from a Garmin GPS with data from a Kestrel datalogging weather meter... similar problem![]()
Thanks... and I was just teasing you... the data from the Garmin and Kestrel are both available as XML downloads... and I just happened to have an XML parser in Squeak (formerly known as Smalltalk). So it's not in "script" form, but in the form of class libraries.In that case you should write the script and I'll just use yours instead![]()
In all seriousness I hadn't seen that thread before(Elise owner after all) and as an engineer/researcher by trade I love your data driven approach.
That bike costs more then most miata's!Come on guys ...
If you want some Heart Rate - spend some time on one of these -poke-
