1 - 20 of 38 Posts
I will be tracking my Lotus for the first time, and wanted to see if there are any things I should remember/know about. I guess it will be pretty hard on the motor, break and tires..
Please let me know what I should know. :shift:
Don't lift mid-corner or if the back-end starts stepping out. :panic:
Actually, how hard it is on your car depends on your driving style. I have found that tracking my car is far less punishing on it than I thought it would be...but then, the fact that I'm slow may have something to do with that. :shrug:
Just have fun on concentrate on learning and safety. :D
" Elise/Exige Track Day "Tech" Checklist? "
http://www.lotustalk.com/forums/showthread.php?t=46332
" Track Tips for Novice Drivers "
http://www.lotustalk.com/forums/showthread.php?t=25850
" How do I get on the track? "
http://www.lotustalk.com/forums/showthread.php?t=25516
" Pre-race day prep??? "
http://www.lotustalk.com/forums/showthread.php?t=24603
" First Elise Track Day! "
http://www.lotustalk.com/forums/showthread.php?t=22568
" Track Prep: Questions on Safety, Spares, References, and Accessories "
http://www.lotustalk.com/forums/showthread.php?t=20464
" After Track Checklist for Elise "
http://www.lotustalk.com/forums/showthread.php?t=15661
" Elise-specific pre-track checklist? "
http://www.lotustalk.com/forums/showthread.php?t=11960
track days HPDE inspect inspection tight tighten check change learn toelink link brake break pads thickness rotor fluid tires tire first time newb newbie know checklist tech technical sheet check list don't dont lift easy pressure pressures instructor flag flags listen pass line lines water fluid fluids oil drink hydrate dehydrate dehydration listen tips flush sunscreen sunblock
I got pretty much all the safety gears... helmet, suit, gloves, shoes, shirt, etc. pretty much all except the nomex undies and HANS.
Too geeky to go on a full racing suit? I think many people show up in jeans...?
Enjoy the "full dynamic capabilities" the manual describes. Get on cam and stay there a while. Feel out ABS, stop like never on the street. Let people pass, possibly follow them if your instructor likes their line. Say Hi to other drivers in the paddock. Don't race anyone. Keep breathing. Tell stories. Have fun. :D Oh yeah, record if possible.
There is almost as much info on this site about tracks technique as there are questions about the Elise as a daily driver...
Listen to your instructor. You are going out with an instructor, right? Don't try to drive too fast, especially into the corners. Learn the line. Be smooth. Know the rules for passing. Know what the flags mean. And, oh yeah, don't lift.
Who cares what others think?, you will be safer in Nomex head to toe.
(I must admit I don't wear mine for HPDE's, just the w2w stuff.)
Send me a mailing address. I'll send you a copy of my magazine (High-Performance Driving) which has good info for beginners. That said, I'll give you three pieces of advice right here:
- When your coach tells you to be smooth with your steering and pedal inputs, take him or her seriously. Smoothness is the key. No abrupt motions.
- Look as far ahead as possible. This has a miraculous effect on smoothness.
- Accept the fact you are slow and that you have a lot to learn.
when you show up to the track, leave all the other crap in your life behind. focus on what you are doing.
the stuff you left behind will stil be there when you are done.
Don't drive beyond your limits, bring an instructor to safely figure out what those limits are. Bring and drink plenty of fluids.
All you have to remember is keep that gas pedal mashed to the floor. If you are not first, you are last!
(I'm just kidding, of course.)
Listen to your instructor. You own a car far more capable than you are. You are about to fall in love with your Lotus all over again!
Discussion Starter #13
"Be safe and be gentle"...
I guess it is just like popping a cherry. ;)
Thanks for the advises! :up:
My usual advice for your first day at the track:
1. Bring a helmet
2. Listen to your instructor
3. Have fun.
That's it. You can worry about R-compound tires, Motul 600 brake fluid, pyrometers, and all manner of modifications and racing gear later -- after you decide if this is for you.
Oh, one more thing. Do not focus on how much this is going to cost you after you get addicted. :panic:
Drop your pressures so she's doesn't go ever the edge too quickly. Then just drive her gently for as long as she can hold on. And if you lose control, just lay back for a couple minutes and the yearning will return again and again and .........just like the first time.
Super Moderator
Completely off topic, but when did "popping her/a/my cherry" become non-vulgar? They used it on a 7:00pm sit-com a couple days ago and I had to explain it to my wife. I'm no prude, but I always thought it was a very crude saying and am surprised that it's now considered acceptable.
And to the question - don't lift in the corner, and turn in under at least even throttle.
It's crude, but when was it ever vulgar?
Super Moderator
The definition of vulgar is :
Vulgar:
1. Crudely indecent.
So I'd think we're saying the same thing.
first time at track:
  • Under no circumstances should you worry about, think about or keep track of lap times. Focus on getting the details right (braking, turning, line, etc).
  • Get instruction from as many instructors as are available. Everyone has strong points and weak points including instructors so a variety will give you a better overall picture.
  • Be smooth with all inputs
  • Do not worry about being passed by [insert slow geeky car name here]. It's going to happen. He/she is simply a more experienced driver. Keep listening to your instructor and practicing and you'll be passing them next year -- maybe even by the next event.
  • Have fun
Oh yeah, don't worry about lap times. If this is your first time at the track, you WILL be slow, so focus on doing everything correctly and the speed will follow.
+1 nicely put
1 - 20 of 38 Posts
