http://www.accusump.com/acc_products/acc_units.html
~22" long, 4.25" in diameter.
I know that Exige had it in the trunk. That would be fine, but if it would fit in the engine compartment, that would be MUCH better.
Mounting is the only thing i'm not sure of. Plumbing the lines is easy - as long as the oil cooler tubing is accessable, it's as simple as throwing a t-fitting in there. then just wire up the valve, and you're off!
