1 - 11 of 11 Posts
Hey guys,
This is the first time the Elise left me stranded in 5 years of ownership. Was driving and pushed the accelerator pedal and the cable became extremely loose. I checked the pedal connection and the throttle-body connection an it was still attached, just loose. The car runs fine, there is just no acceleration now with the loose throttle cable. I have not had time to take off the under panels to diagnose the problem and I have not seen any threads about replacing the cable/broken cables/loose cables. So I'm just trying to get some feedback to what may have happened. I did not hear any pop (broken cable) so I'm not sure if it's actually broken or just loose somehow. I have no Idea how the cable is installed, so any explanation or diagram would be greatly appreciated. Hopefully, I can dive into this problem and get my Elise back on the road soon! Thanks in advance! :unsure:
If it's just a loose cable you should be able to tighten it at the throttle body , there are two nuts on either side of a bolt to adjust the slack in the cable .
Sent from my Pixel 2 using Tapatalk
I remember cable breaking on my Elan (or some car). I just turned up idle higher and drove. NG technique with modern cars.
But, I imagine I could duplicate a bit of that with a paperclip or two. Or, Vise-grip pliers.....
On his Elan, my cousin used string and had a hand control throttle.
Cable should still have a bit of room in it when throttle is fully open, so the stop is on the throttle, NOT the cable.
Thank you guys!!! I will take a look an see. I hope the bolts are just loose. I don't have any experience with the throttle body/cable so I may have missed that.
Have you had someone move the accelerator pedal while you watch the cable in the engine compartment?
Or checked the connection at the pedal. You might need to hire a small child for this step.
Not yet, that will be the next step...
Discussion Starter #10
So I confirmed last night that the cable is broken. I just pulled the wire through the sheath. I think it broke somewhere near the shifter. I started by jacking up the car and removing the two rear under trays. It was a little tricky removing the cable from the throttle body and then cutting the factory zip ties. One zip tie was located way down in the engine bay, I had a hard time cutting that one (I don't think I will be replacing it). Now I have the 1st half of the cable pulled under the car out from the engine bay. Now I just have to see how much interior hardware I need to remove to get the cable pulled through. I have already removed the shifter cover and exposed the shifter frame assembly. I just hope I don't have to remove it and disconnect any shift cables to run a new throttle cable through the firewall. Also, I'm thinking about removing the seat to assume the "Lotus Position" because i'm 6'2" and I can barely reach up in footwell. This may take a while, I still have to order a new cable. :cautious:
Still, good start.
1 - 11 of 11 Posts
