What are the front and rear wheel and tire specifics?
Are you going to extend the front fenders to envelop the wheels and tires (and mate up with the very wide front of the side sills)?
What are the front/rear fender extensions, side sills and rear diffuser/extension going to be made of? It better be tough stuff, or you'll be seeing it in the rearview.
Do you think you can get enough heat into the tires (front and rear) to take advantage of the width?
No flame suit needed. I'm curious, and in no way mean to seem disrespectful. Best of luck and keep us apprised.
Great questions.
Yes, the front fenders will be extended to match the sills. The front spoiler 3.0 is going to be re-made now to again match the width also.
This will all be carbon fiber.
I run the car at air temp of 30-36 degrees centigrade. Power level 400whp +, I might even try high torque again in my next engine rebuild.
Magnesium alloy wheels. 10.5 rear 20lb in weight, Hoosier 275 width. 9 front Hoosier 225 - Hoosier are wider than my Toyo 888 for same width.
I'm quite sure I can get enough heat into the tires for them to do the job.
I'll need to drop the car lower too....
Great questions.
Make sure you have enough clearance from the top of the tire to the inside top of the fender/flare extension to accommodate full compression. It looks tight.
The wheels are ReDRuM Race wheels. Zen 1.0 design. For my next set I might adjust the offset since I wanted to go a little wider and so here I'm using a 12 mm spacer. Here's a picture with the center caps
Yes, go big or go home philosophy.
No access to wind tunnel. If nothing else the sills look cool I think.
Gonna make some funky looking louvres over the front wheels...
I know I'm being a backseat designer, but if you can bring the height of the extension aft of the wheel well to the same height and contour as the OEM rear deck - IMHO will give a more cohesive and less add-on look.
Yes , could match the deck , but that might create unnecessary drag. Aiming for a tad more function than form really. I reckon this will look the biz once it's in carbon fiber.
We've looked at multiple race oriented cars and we're mimicking the same lines.
Cool project, I image you enjoy doing this kind of work.
Question for you. Did you consider buying a more turnkey GT3 wide body kit, saving yourself the effort, and using a tested aero body style?
BTW: The last wind tunnel analysis I read on the Exige proved the rear diffusor outter most fins need to be at most 40mm off the ground for maximum effectiveness. Your's look too height, assuming that's your final ride height.
I have the straight version and not the version that contours with the body, maybe that is the difference. My tablet takes bad photos (and sideways it seems) but this is several track days without a wash.
I'm curious what you have in store for the front splitter. Are you integrating diffusers that channel air into the now-vented wheel wells? Are you going to vent the top of the fender arches?
Making the diffuser outer fins extend forward more is also of benefit... getting the leading edge in front of or even with the forward surface of the tire likely helps prevent turbulent air coming off the tire from corrupting airflow in the outermost channels of the diffuser.
I did some crude wool tuft testing using a stock Difflow diffuser and some cardboard modifications: Diffuser Tuft Testing
Thanks for that info. These will be similar but using foam core. Little thicker carbon fiber sandwiching the foam core. These will need to be sturdy since their going to be quite wide.
I'm using my battery tender now sporadically (because my car is stored outdoors and I can't leave the hood unlatched 24x7 while I'm away). I'm seeing some interesting results from the tender and I'm not sure how to interpret it. I'm using a Duracell battery maintainer (SLC10002) and when I...
Hello.
I have a 2017 Elise Sport. I'd like to upgrade it a bit. As far as I know to do the Komo Tec upgrade you send your compresor pulley to them, they modify it and then send it back to you.
Does any one know the final size of it?
Thanks
Hello,
I was wondering if most of you do work yourself or do you pay to get it done? Would you all trust one of those quick coolant flush places or rather just do it yourself?
