1 - 12 of 12 Posts
I tried searching and did not find a clear answer. I plan to mostly drive on the street and autocross. Will do a couple of track days a year.
Currently have the original 048s, with about 8500 miles. The fronts are still ok, but the rears are about gone.
I plan to stick with the original rims. Should I just get 2 new rear 048s, or go with 4 new tires? What brand, model? I would like to be as competitive as possible while still driving on the street.
Thanks!
Rob
My front A048's were so hard from age and heat cycles when the rears were worn out that I replaced them. The fronts had 5/32 of tread on them so they probably would have lasted well over 25k miles if I did not mind massive understeer and poor braking. Check the DOT build date on your fronts to see if they are less than 2 years old, if so they might be ok for a while. The last 4 digits after the DOT code are the week and year they were manufactured. Go with R888 or R1R Toyos depending on your grip/longevity preference.
I know some people with R888's and they are very happy with them on the street and for AutoX.
If you are looking for something a little cheaper the Falkin Azinis are also pretty good.
Let me ask another way, I see several choices. Pls let me know if you have any thoughts/experience with these:
Falcon Azenis 615
Dunlop Direzza Z1 Star Spec
Yok Advan Sport
Nitto NT-01
Bridgestone RE-01
Hankook Ventus R-S2
Of these, local autoxers have been using Direzzas and Azenis. I appreciate any feedback.
Rob
For AutoX the class you run will help decide...
I run Star Specs daily (and in STU last year) on the Evo. They have a fairly stiff sidewall (good for the portley Evo, but likely not needed for a Lotus). Great grip for a street tire though. They are lasting fairly well (have ~6 events [including about 23 80-90 second runs at Mineral Wells [gravelly] over two days) on the + 5500 daily driver miles on them). The stock Yoko Advans lasted 6000 miles or so, but that includes daily driving and my hamfisted autocross technique.
ETA: the Falken 615's are two years ago "tire to have." They aren't great any more. The RE-01 was 07's "tire to have". The D1 was 2008's.
There is also a new Nitto street tire coming out that's getting favorable reviews: Gates311: Nitto NT05 Review **Street Class Tire ** - evolutionm.net
1 - 12 of 12 Posts
