thegit said:
i might be talking cr*p he but it seemed to me from some S1 tech papers, that the tierod had to be popped out of the spindle to adjust toe.
Is this correct?
Nope..
Toe adjustment is done with everything in place.
At the front you just undo the locknut on the steering arm and then screw them in/out of the track rod end.
At the back you undo 2 lockunts on the track rods and then turn these to shorten/lengthen them.
Very simple. Very, very sensitive though, especially at the front. Keep a good eye on the alignment machine when tigthening the locknuts again as this probably moved the toe setting... Need to take this into account..
Bye, Arno.
