Correct. I have my torque pro with a bunch of mods and software updates. Never an afr reading from the 2zz. Also no afr with the k20. Id recommend just buying a wifeband to monitor that.
Pretty sure the Toyota 2ZZ doesn't use a wideband O2 sensor... Could be wrong.
So in that case you won't get an A:F, you'll only get voltage.
You could try entering the enhanced PID's into Torque.
But pretty sure they won't work, well you might be able to get the Commanded A:F and see what the ECU wants.
Open Loop Commanded Air/Fuel Ratio
OBD2 PID: 0144
Long Name: AFR
Short Name: AFR
Minimum Value: 0
Maximum Value: 20
Scale Factor: x1
Unit Type: A/F
Equation: (A*256+B)/32768*14.7
OEM Wideband Air/Fuel Ratio
OBD2 PID: 0134
Long Name: WAFR
Short Name: WAFR
Minimum Value: 0
Maximum Value: 20
Scale Factor: x1
Unit Type: A/F
Like others have stated, there is no wideband on the car. Very rarely do they come with widebands. The only car that comes to mind that has one is the newer Mustang 5.0. You need to install a wideband sensor and a gauge in order to see it.
