Rec'd this msg from a friend. I don't know the answer, so help would be appreciated.
"My 94 porsche 968 racer uses its original OEM Torsen Type limited slip differential…..
With wheels unloaded on lift, should my torsen LSD diff act similar to open diff whereby opposite wheel does not turn when 1 wheel is rotated?
I believe a more traditional clutch type LSD will have opposite wheel rotate same direction…
I believe open diff may have opposite wheel rotate in opposite direction…
Can you confirm or clarify?"
TIA.
=gb=
TIA.
=gb=
