I've been having the following problem with my '11 Evora since a couple of weeks after I got it. Any tips would be appreciated.
The pre-cursors to the symptoms have changed, but the essence of the problem is this: occasionally, when I try to start the car, there is a total loss of electrical power. It is as if someone has disconnected the battery: the speedometer and tach freeze wherever they happened to be, I can't open the glove box, I can't unlock/lock doors, etc. I will turn the ignition to 'on' and it will go through its typical self-tests normally. When I turn the key to start, one of two things happens: (1) the car immediately dies, or (2) the starter tries to fire a couple times (there is the clicking sound that occurs when your battery is too low to start the car) and the car dies.
The car eventually comes back to life after some period of time between 10 seconds and 20 minutes. However - if I close a door or otherwise jostle the car, electric power is restored. Sometimes. The most recent occurrence was last week I tried to start it in the morning and it died. I opened and closed the driver's door and power came back, tried again and it died. No luck with the door trick, so I took a different car to work. That night when I got home, the car was still dead. I opened and closed the door and it came back to life. Tada. I've been driving it this weekend and it's been fine.
Initially, this would only happen after the car had been driven for a significant distance (say >50 miles) continuously, irrespective of whether I was driving it hard or in the right lane on the highway on cruise control. I took it in to the dealer and they found that the main relay connection was loose, and they tightened it. Since this has only ever happened sporadically, it's hard to say whether it has helped.
My thoughts:
- some other loose connection(s) somewhere
- nearly-drained battery
- gremlins
I have tried resetting the inertial switch while the car was dead to no effect. It appears to be something else.
I need to confirm, but the car was built in fall 2010 and I picked it up Jan. 2, 2012. I know the car has higher-than-normal current draw while off, so any thoughts on maybe an undervoltage to the ECU or something else that's triggering the cut-off?
Anyhow, it's going back in to the dealer on Monday, but I'd appreciate any thoughts on what might be causing the problem.
My thoughts:
- gremlins
