Parts came from a 2005 Elise with 55k miles
Additional photos: K-Swap Superfluous Parts
Body Wiring Harness - A121M0001F - $500
the only place I found some problems with the harness was at the radio. Looked like someone rewired/removed the OEM connector. I removed the radio and dash for track use.
Engine Harness - B120M0004F - $sold
Rear Harness (in trunk) - A121M0012F - $50
Lotus ECU - C121E0001F - $sold
Innovative Rear engine mount for 2zz-GE - 60530-75A - Bought from BOE - $50
Exhaust Manifold - A120E6331S - $sold
Exhaust gas recirculation tube was cut and welded closed - Makes install and removal much easier, you can remove this with the clam on.
Inlets were ported to the pipe diameter.
Outlet welds were smoothed for flow.
Exhaust Manifold - JDM without EGR - $25 unit unmodified.
Starter - A120E6400S - $75
Alternator - A120E6369S - $sold
Transmission - C64 OEM Lotus unit - $1200 - shipping will be at least $125 plus insurance
Open differential. It shifts well. The engine was normally aspirated.
Slave cylinder - A120Q6011S - $30
Flywheel - A120E6195S - $25
Drive Shafts
Left side - A120D0019F -$sold
Right side - A120D0018F -$sold
Throttle Body - A120E6353S - $sold- I added a bracket and bolt that repaired the butterfly valve intermittent sticking, has work fine for 2 years.
Intake plenum - A120E6321S - $50
JDM intake plenum with angled inlet - $50 from JDM engine
Stock Airbox Cover is damaged. the base is good - A120E6383S - $25
Air Box Bracket - A120E0004F - $15
Fuel Rail - A120E6362S - $50
Fuel Injectors - A120E6361S - $10 for all 4.
Charcoal Canister - A121L0002F - $25
Recirculation pump for cooling system - A117K0013F - $40
Gear Shift Selector assembly - E120F0001F - $200
PM or email [email protected]
parts are located in Hobart, IN 46342
