41 - 45 of 45 Posts
Mods......
*TCKline shock & spring set 500lbs front 550lbs rear
*Ground Control Swaybar set
*Slightly oversize SO3 tires on 19" rims
*Mintex Compettion pads & Motul 6000 brake fluid.
*Dinan chip & exhaust
Discussion Starter · #42 ·
A lotus engineer was quoted during an interview with Autoweek saying the 2ZZ-GE was good for 300HP. I'm not sure if that was NA or FI. It may take a while for the mods to become available. 300hp would give you a 7lb/hp ratio for the Elise in comparison to the 8lb/hp ratio of the Z06. Of course handling would be dependent on suspension set-up but 2000lbs compared to 3100lbs would give the Elise a significant advantage.
mikester said:
My point was simple, and you made it yourself by saying that the 'vette weighs 3300 pounds. These are two very different beasts.
Closer to 3100 lbs. They are fairly light particularly considering how muscular they are, although they don't drive as light as you'd think a 3100 lb cars should drive.
41 - 45 of 45 Posts
