I had the tires mounted today on my new Kodiak wheels and they look great. Kodiak said I could epoxy my sensors in the wheels but that would ruin the sensors if I decided to move on to different wheels in the future and I would then have to buy new sensors.
Here's my TPMS fix. I decided not to epoxy the sensors in the wheels as suggested. I took a piece of 3" PVC pipe and drilled a hole for one of the sensors at the half way point of the tube. I then mounted that sensor in the tube with the stem sticking out and bolted the sleeve down tight (use a little silicone to ensure seal). I then used PVC glue and put end cap on one end of the tube. Then placed the other 3 sensors in the tube with a little bubble wrap (after all I'm not making a rattle). Then I removed the needle from the valve sticking out and glued on the other end cap on. When everything was dry (wait 24 hrs - don't get impatient), I replaced the needle in the valve, filled the tube to 40 psi, placed it in the trunk with velcro and sha-bang, the TPMS light when out.
I think I'm smart enough to check the air pressure in my tires regularly. I don't need the idiot light to remind me.
