I am looking to setup the car for an upcoming track day and have a few questions. Hopefully someone can help me confirm these settings.
I have the Track Pack shocks installed on my LSS car. I am looking to run around the Lotus recommended ride height settings. I want to run 120mm front and 125mm rear (have seen many keep a 5mm rake). These settings are assuming the stock tires.
I will be running Toyo R1R's at 205/45R16 and 235/40R17's. From checking the sidewall difference between the stock A048's and these new tires, I find that the fronts will be 5.3mm lower and the rears will be 7.2mm lower. From this I get a final ride height on 115mm front and 122mm rear (to maintain the same rake).
Have I done this correctly? Note, all these settings will be achieved with the Lotus recommended 330lbs in the car.
I have removed all the front camber shims (including sensor bracket). I am planning on 4mm total toe-in on the rear and 0mm toe in the front.
It also looks like the stock swaybar could have an additional hole drilled to provide a little more stiffness. Has anyone done this?
I am open to any suggestions/recommendations, etc. I appreciate any input.
