1 - 10 of 10 Posts
Ok I have a shock down and I'm trying to figure out the part numbers of the rebuild kits if they are available? Has anyone done this or do I need to send them back to bilstein?
07 Exige S
I sent mine off to Bilstein. It took approx 2 weeks from when I sent to when I got it back. It was $170.
someone gave me the address in Pomona, CA. I can find if you need. peacb
Here it is:
Bilstein Shock Absorbers
A ThyssenKrupp Automotive Company
14102 Stowe Drive
Poway, CA 92064
858-386-5900
You can also have it revalved for higher settings.
Thank you for the responses! That should get me on track.
Jason
07 Exige S
Beats me to it ! Alas I have the all important email address ! I get an extra point for that I believe ?
14102 Stowe Drive
Poway, CA 92064
(858) 386-5900
E-mail: [email protected]
Discussion Starter · #8 ·
I honestly couldn't tell you. I bought them used and don't know how they were treated (tracked?). The claim was 16k but if it's 16k of track only then I would expect an excelerated failure rate. I can't attest to the exact mileage claimed but for the money I have invested so far, I'll have no problem paying for the rebuild!
how did this workout for you?
I have a set, and want to get the seals changed, as a few are leaking.
but at $170 per shock thats not really worth my money, so im thinking of rebuilding them myself
Discussion Starter · #10 ·
Unfortunately the set I have were not customer serviceable and required machining to retrofit a schrader valve. I'm not saying it can't be done but this isn't as simple as changing a few o-rings and recharging on the first go around. Mine had more problems than a simple leak and had internal damage not allowing it to be adjusted with the knob. My right front wasnt dampening anything!
Honestly it went very smoothly and would recommend using them.
1 - 10 of 10 Posts
