1 - 6 of 6 Posts
It's not too bad, you will need to drain the trans, pull the axle, remove the shaft seal and drive in a new one. Probably 1.5 hrs for someone who has done it before, your results may vary....
Are you sure it is transmission oil? Not a leak or drip from above? Before you order parts and tear into it, or pay someone to do that, smell the oil from the leak. compare that to the smell of your transmission oil and engine oil. Transmission oil, especially used, typically has a distinct odor that you can tell apart from engine oil.
Based on your pictures, your car does not appear to have very many miles on it. It would be unusual for the output shaft seal to be leaking unless the stub axle has been removed in the past and a the removal or reassembly might have nicked the seal.
Yeah even I haven't had a drivers side seal fail like this ;) Maybe someone spilled oil when filling? I think it ends up about there.
2005 Elise LSS Saffron Yellow
That's the right side axle seal which, as others have said, essentially never leaks. I'd look at other things that might be oozing down there and dripping onto the axle or transmission.
Unless somebody pinched the seal when putting the axle back in there's just no reason it would start leaking - the other end of the shaft is located by a bearing, so the only motion the seal has to deal with is rotation.
They're very long lived: My '92 Celica uses the same seal on its C56 transmission. I've had the shafts out twice and the original 1992 seals still don't leak a drop.
Thanks for the feedback, so far I did not found any other source for this leak, I do my oil change and I’m sure I did not do à mess ?
This is driver side. I did cleanup the leak and will keep an eye to make sure.
1 - 6 of 6 Posts
