I replaced the rear tires after 12,000 miles - the tires were worn in the middle, but still had tread remaining towards the outsides.
I decided to use 27 lbs. pressure on the new set (rather than the recommended 28) in an attempt at evening out the way the tread wore. After 13,000 more miles, the wear pattern has been the same - no tread left in the middle. I plan to try 26 lbs. pressure on the next set.
So far the front tires are wearing evenly and have plenty of tread left while running 28 lbs. in them.
Any thoughts on tire pressure VS tread wear?
