1 - 7 of 7 Posts
Last night, I removed the panel cover, unscrewed the bolts... lifted the front portion (which was fine), and couldn't get the rear portion to release... any suggestions? thank you!
insert clever title here
Did the rear brackets come loose, or are those what's stuck? You know, the bracket the screw holds tight, that just flops around once you loosen the screw.
Not really sure what you problem could be, I've only removed my hardtop once and had no problems. Maybe try loosening the screws more, be sure they're fully disengaged (they're captive, so won't come out though).
1 - 7 of 7 Posts
