1 - 20 of 37 Posts
I have THE most annoying rattle in my 05 Elise. The rattle occurs when momentum shifts to the front or to the back. If I hit the brakes hard, whatever it is flies forward. If I hit the gas, back it goes. It sounds like a handful of dimes moving around. I was hoping whatever it was could be found under the seat, but with carpet there, that's out. I'm guessing that it's either in the piece of aluminum that goes across the car, from driver's side over to the passenger side, underneath the shifter, or in the center console itself. Hard to tell by sound. My guess is that it is coming from the center console because the length of travel is longer. The sliding sound when the pieces are moving seems too long to be in the transverse piece of aluminum. That part is not that large in the front to back direction.
I dont feel confident taking apart my car, but I'm wondering a lot what could be moving around inside there. Parts of the shifter? Or maybe parking brake? The sound is coming from the back of the console so maybe that's where parts might be missing.
Console removal is not that hard. Plenty of posts here tell you how. It is a good learning experience! You could also use the console removal as an excuse to put a leather gaiter on the parking brake. Get one from Redline Goods. They make them custom with LOTS of color and stitch options... I replaced mine with double orange stitching over perforated black but he literally can do anything.
Another thing to do while you are in there is the shifter reinforcement which will tighten up the shifter mechanism and makes a big difference. See http://www.billswebspace.com/ShifterReinforcement.pdf and you can search other posts by posting this into your browser search " site:lotustalk.com shifter reinforcement " (best way to find anything in this forum!)
Good luck in finding the noise!
Addict
I would not rule out something under the seat. Stop hard enough for it to roll forward and pull over to search without it rolling back. Then check the center console.
My assumption is center console. When I removed my center console, there were pennies, dimes, nickels, and quarters in the center runner. There were so much it didn’t slide anymore . Previous owner left it all for me I guess. Not that difficult to remove at all. Good luck
Gabe
Underneath the seat is entirely carpeted so it's impossible for a metallic sound to come from that surface. The pieces moving around are definitely making a sliding on metal sound.
Gabe
I looked at older threads on removing the center console and most of them describe the process as quite difficult. I am sure for most here it's easily possible to do the work yourself, but it is impossible to overstate how much I am NOT a gear head. I have not done any significant work on a car in 30+ years. So my confidence level can be accurately stated as "rock bottom". Best left to those who have knowledge.
Anyway, it sounds like an easy fix for those with skills.
Moderator
Interesting. My gut feeling is that this might be the source of the sound, simply because the sound has a very "uncovered" sound to it. I feel like I could reach out and grab whatever it is that is rolling around. I would think that if the sound is coming from the console, it would be slightly muffled, which it is not.
That said, I have no idea how to address the problem and so will leave it to someone not as clueless as myself.
The space under the console is pretty tight, it is hard to believe things are really regularly sliding around under there .
Things do slide around under the seats, even with carpet
I wonder if a squirrel has left something in the side sills, they are open at the back to the outside
Discussion Starter #10
That would be a strange illusion as the sound is 100% underneath the seat and to the right. But I am intrigued by your suggestion, because it does sound like a lot of junk that is moving around. Where is this opening that the squirrel can get in? Is it above the diffuser?
Discussion Starter #14
It could be above the the undertray. May try tapping the undertray hard with your knuckles and see if anything rattles. I did this routinely anyways just to see if any undertray screws are loose.
I'm sorry, but I am an extreme noob. What is the undertray? I am afraid I do not know many of these terms.
Discussion Starter #18
This thread has me worried. I really wonder if a chipmunk has stashed a bunch of food inside my car. My area is crawling with these little guys. It doesnt help that my daughter feeds them peanuts!
Discussion Starter #20
The undertay is a metal panel that bolts under the engine. If you look below the car, you'll see it plain as day.
Thank you. I always thought that the metal sheet underneath the car was called the diffuser. Now I see there's more than one part underneath there.
1 - 20 of 37 Posts
