1 - 11 of 11 Posts
Is there anyone in the Houston area willing to trade time and expertise for beer? This has become a matter of pride for me...
I believe my thermostat is on the way out so I'm trying to replace my thermostat before an overheat, but I can't even find the dang thing; let alone start to replace it. I've been trying to follow diagrams and pictures on LT, but with the intercooler it's a mess down there!
I even tried tracing the belt to the water pump but I can't see around the alternator.
I was also reading some saying to remove the supercharger and go from above... I haven't tried this since I had it professionally installed and haven't done enough research to put it back together, but if that's the route I'd be confident enough to go that route as well.
Anyway, tips from the masters?
(Other than the BOE supercharger the only other mod in the area is the radium quick clam removal)
Gamera The Atomic Turtle
subscribed....
Tire abuser
You need to remove the alternator. It's not that bad after that. A pain, but doable. You need a 10mm socket with a swivel and an extension. Access is mostly from the right rear wheel well.
I just replaced a friend's thermostat in his Rev 400 Elise. In my opinion it is quicker to take off the SC and manifold. This gives full access and removing the alternator is not that easy in itself. Clam off.
Tire abuser
Probably comes down to what you have "practiced". I have had the alternator off three times now, including replacing it in the track parking lot once, and it is no big deal anymore. Have not had the S/C off, so that seems like the thing to avoid to me. Your input is interesting for when I eventually have to do that too.
Well, overheat is not the issue; running too cool with therm stuck open equals more condensation water in engine/oil, mechanical bits not expanding to normal running sizes, etc. Too cool can be almost as damaging as overheat if prolonged.
Discussion Starter · #10 ·
I'll take some pictures this weekend of what it looks like from my perspective.
Dspecgsx I'm just trying to mentally align your camera, correct me if I'm wrong. Is your camera middle-ish pointing towards the right wheel well? If so, I think there's some plastic wall from my intercooler in the way... GRRR!!!
1 - 11 of 11 Posts
