1 - 8 of 8 Posts
I was doing some exhaust work on my esprit today, and I had one of the nuts on the turbine outlet stud seize up. No big deal, I thought....I'll size back the stud out of the turbine housing and deal with it. Well...... the stud didn't want to come out of the turbine either. I got it out, but the threads are totally thrashed! I'm going to have to bore it out and use a thread repair kit on it, such as a timesert or a helicoil.
So, here is my question. Does anyone know what size the threads are that go into the turbine housing? the side the downpipe bolts onto is an M10x1.5 , but it seems that the turbine side might be a 3/8" x ??? (hard to tell becuase the threads go so damaged and rounded off) . seems odd to have standard on one side of a stud and metric on the other, though. Maybe the whole stud is M10x1.5 on both sides.
Also, do you know where I can get another stud? maybe JAE....
thanks,
Andrew
Wingless Wonder
1988 Esprit Turbo
Just looked at the studs in the parts manual, the size is not specified. :sad:
But I'm sure Jeff @ JAE stocks them....(or at least knows the size).
When I destroyed the "button-head" bolts getting my engine's rear main seal off, I couldn't find replacements locally. But Jeff had them. :cool:
This seems to be a common problem. I'm pretty sure they are M10x1.5 on both ends, but they have a deformed thread to act as a threadlocker. Once you bugger up the threads in the turbo there's not a lot that can be done. The price of the actual, original stud will make you weep. Once you replace it, I suggest not using a locknut, but instead drill some non-locking stainless steel nuts for safety wire and safety wire them in place. Been there, done that. :(
Wingless Wonder
1988 Esprit Turbo
WE NEED PICS!
Not of the studs, Sanj, but of you, weeping....
rotfl
:coolnana:
Sanj,
you were right. $42 for a single stud! OUCH!
I was able to find a stud locally, though. I ended up buying a helicoil repair kit. I couldn't get a timesert set locally. found some time this afternoon to drill out the "knackered" threads, tapped it, and helicoiled!
thanks for the help everyone.
Man, did this come up at the right time, I just developed a rattle and traced it back to one of the studs having rattled out. Does ARP make replacements? I did a quick search online and found these. I am a little worried that you get what you pay for though....
Fasteners : atpturbo.com
i got my new stud at a local ace hardware. it was an "automotive stud." looks similar to the atp picture.
1 - 8 of 8 Posts
