1 - 4 of 4 Posts
Anyone have a suggestion on where to pick up high pressure oil for the turbo charger? Anyone know where other kits get the supply from (oil cooler line T perhaps) I saw the extra plug near the two cooler fittings don't know how high of pressure it is though
Forum Founder
Sandwich plate? T-fitting off the lines to the oil coolers?
I have no idea. Just wanted to mention that if that is your car, note the wear on the U-Tube for the coolant return (where your fingers are touching). That is a failure point.
You have to install an adapter in between the factory oil pressure switch and the block.....it' right above the cooler lines. The fitting itself is kind of special as it has to a bsp to npt adapter...we sell them if you need to buy one.
1 - 4 of 4 Posts
