121 - 140 of 211 Posts
Project Addicted
Discussion Starter #121 (Edited)
SHIPPED!!
Tom Mieczkowski = mieczkow PAID Shipped
1989 Turbo Esprit
Jim = Lotus4s PAID Shipped
1995 S4s
fsrowsell PAID
Deer Lake
Sanj x2 PAID Shipped
Don = CarSalesman PAID Shipped
Esprit S4s
Scott = greentengu PAID
1986 Turbo Esprit HCi
Kenny = MidLifeZ x2 PAID SHIPPED SHIPPED SHIPPED
Dallas Tx
Andrew = quadcam PAID Shipped
Flo-rida
Redfox Paid
DENMARK
Rich = Flowersjr PAID Shipped
PA
Eric = EW 89SE PAID Shipped
in 47408
Ian = Ianarm77 PAID Shipped
Colorado
Derek = Sailorbob PAID
Steve = Ragingfool35 PAID
Aaron = ATSAaron PAID Shipped
AdamW = Faykfox PAID Shipped
Vegas NV
JonF PAID Shipped
Austin
ATS PAID
Denton TX
ChrisO PAID Shipped
Pinellas Pk
StewartM PAID Shipped
ZbigniewG PAID Shipped
Jenna PAID
I had to ask a few for address clarifications. Paypal didn't have the ship to for everyone.....
WOOT! GOT MINE! Install planned for this weekend!
'95 S4s & '79 JPS #040
Hi,
If I wanted to use the full "fat lip" velocity stacks that MrDangerous mentions in the "X180 IMPROVEMENTS" topic (post 65) in my S4s along with this 1" spacer, how high should they project above the surface?
Thanks,
Rich
Spacer arrived today. What a nice workmanship.
Thank you Derrick for great design and Jonboy for putting the group buy together.
Zig
Got mine in the mail today! Gaskets came from JAE yesterday, too. Just about all set. What size and length bolts we need to use with this spacer? Thanks !
I failed to think about local stores not having long enough bolts, etc. Did find one which had M8x1.25 threaded rod though so am going to cut to length... :p
Installed! Took a bit longer than anticipated due to PO must have had the intake cover at some point and when it was put back they put some sort of RTV/Silicone/??? on both sides of the paper gasket. It was a MESS getting it all removed, gooey, goopy mess!
Had to remove the air cleaner cover as well
Going to chill out a bit before take out for a drive. Looks cool though! Just need to finish cleaning up the mess..
Wingless Wonder
Now Kenny and the others will have as much fun changing oil and charging the A/C as us Bosch guys! ;)
Does look nice tho'. Would have been nicer without Kenny's fingerprints. rotfl
Wow, that looks great!!!
Fit was good?? If not blame Derek!! If it fits and works well, I will take all the credit :)
Fit was very good, no issues on that front at all. Props to the Derek and the rest who made this possible!
Oil change shouldnt be an issue since I did the oil filter relocation thing a while back.. :)
AC, yeah, probably right on that. Fingers crossed will not have any issues for a long time since just replaced the compressor last year.
Would be much easier if only did one versus two as I did. If only one probably no need to remove the air filter cover and such.
I don't see a need for stainless bolts to be used on the plenum. Mine have no signs of corrosion, and aluminum will oxidize with stainless. If you do use stainless hardware then I would use something like the blue Loctite to minimize the stainless reacting with the aluminum.
Ordering my bolts this evening. Several other positive comments about using stainless bolts. I don't know enough to have an opinion. Should I get stainless or the regular zinc finish?
Project Addicted
Discussion Starter #138
Stainless isn't required, they just look better. If you don't have any preference, then just go to the hardware store and but standard bolts. Use antisieze on all bolts.
PLENUM SUPPORT BRACE
I am thinking of just bending the OEM Lotus plenum support brace so its tab is parallel to the plenum spacer surface and install a short stud on the bottom of the spacer. I would do the same to support fuel return tube and electrical harness. Studs would be Blue Loctited in.
I am planning to use just a flat washer and nylock nut on each stud.
OIL DIPSTICK
With a single plenum spacer it seems feasible to flatten the oil dipstick support brace and just drill new holes. Dipstick would then mount flat against the plenum box, instead of being spaced a-part. Pulling the dipstick out wound be more challenging, but not impossible.
Kenny, with double spacers... how did you attach the plenum support brace, oil dipstick brace, fuel return tube and electrical harness?
Zig
OIL DIPSTICK
Zig
I attached the oil dipstick brace to the far rear bottom bolt. Only needed to attach to one of them. Using both of the dipstick braces attachment points would have been problematic and this solution is adequate IMHO.
The electrical harness was able to be easily attached at the 2nd and 3rd most rear bottom bolts.
I looked at the fuel return line and was not comfortable stretching, etc. it and after looking simply did not attach it and put some rubber hose which I split over it as a safety precaution for any rubbing.
I have not yet reattached the other brace though have looked at it and am open to ideas, etc. I was looking at bending it and attaching to front most bottom intake cover bolt and then to the alternator possibly. Ideas on this or other solution?
EDIT: You are correct in that reattaching all of them, other than the brace itself, would be very easy with a single spacer
