Bulb out.
I think he does have a 2006 Exige..... :clap:If you do not have a bulb out, and you have a 2006 model, then it is a known issue with the LED tail assemblies.
My signal started to do the same thing when I changed the front flashers to the aftermarket LED bulbs that look white under the lenses but flash yellow/orange.When I use the turn signal, the flash/blink repeat rate is like 3x normal.
It blinks, and clicks so fast, it is annoying.
What happened? How is this possible? How does the timing of the blinker change?
Haha i like that!..but it could help tell indicate to everyone "I'm making this turn REALLY FAST!" :coolnana:
+1Bulb out.
Not exactly "feed back" - the flash speed is regulated by the current being drawn (resistance) by all the bulbs. If a bulb is out, the resistance is down and the the flasher cycles faster - it's actually by design so that you know if turn signal bulb is out, and it's pretty much standard on all cars.Was told it Has to do with the power feedback from using non filament bulbs.
+1 Great info.Not exactly "feed back" - the flash speed is regulated by the current being drawn (resistance) by all the bulbs. If a bulb is out, the resistance is down and the the flasher cycles faster - it's actually by design so that you know if turn signal bulb is out, and it's pretty much standard on all cars.
If you change the bulbs to one that has different resistance values, the flasher will work faster or slower depending on the load. You often get the same thing if you connect a trailer (lights) up to the wring of your car (truck). Special flasher units cure the problem in the case of changes because of trailers...
