1 - 10 of 10 Posts
Here is a video of before and after installation of the shiftR111 from InoKinetic. It is a quality piece and you shouldn't be afraid to attempt this installation. I'm working to tune in the second to third shift but the weather is not cooperating for test drives. The installation video is extremely helpful and Shinoo is always available for questions. Good winter project with a nice outcome. I keep telling my wife, "there just isn't anything more I can do to the car" but here I go;}
Very nice. Where did buy the fire extinguisher and holder? I already have the sector 111 piece. Thanks
Could you please do another video where you show us how the gearknob wobble is when you have engaged a gear?
Is there still the same movement as with the stock shifter?
Would like to see this also. I just installed the F&R engine mount inserts which made a huge difference on the shifting feel
2006 Exige
Here’s video of stock shifter with a 10%
throw reduction and reduced play transmission linkage.
Reactions: Catsailr27
Yeah so it doesn't seem as though the shifter movement when in gear is actually decreased that much, just the throw length. In the comparo. you show how much the shifter moves in gear with the original unit, but not when the Ino kit is installed. This seems to be a common theme in the videos I've seen
Less is Better
All wiggle will never be eliminated. Even the Miata's direct lever does it.
You can see the amount of motion after the SSC cables and ShiftR111 in my video here.
Agreed. I have the shiftr111, the Inokinetic upgraded cables, and a LETSLA. The shift precision and feel is greatly improved over stock; there is still some side-to-side play when in gear, but that play is internal to the transmission. You can easily see it if you remove the engine pan and watch from below while someone wriggles the stick. At the same time, there’s no discernible slop in the shiftr111 or the LETSLA mechanisms. IMO this remaining play is a non-issue.
1 - 10 of 10 Posts
