A little snip it from the repair manual about the 918's knock sensor...
EMM.2 - T KNOCK SENSOR
The ignition timing required for optimum performance can lead, under certain operating conditions;’ to
detonation of the fuel mixture in the combustion chamber, causing excessive heat and pressures and a characteristic
‘knocking’ noise. If allowed to continue unchecked, major engine damage can occur. A single knock
sensor is mounted in the crankcase ventilation cover at the front of the crankcase ‘V’, and is able to identify
detonation ‘knock’ and produce an AC output voltage which increases with the severity of the knock. The
knock control strategy programmed into the ECM allows the engine to adhere as closely as possible to the
optimum ignition timing and turbo boost settings without a damaging level of detonation.
Knock sensor
When the knock sensor detects the onset of detonation, the ECM first rapidly retards ignition timing to a
safe level, and then progressively advances ignition until detonation is again detected (if at all), and the cycle
repeats. If however, retarding the ignition does not stop the detonation, the ECM also rapidly reduces boost
pressure before slowly allowing it to build up again (see Sub-Section EMM.2 - R).
Knock sensor
