Hoping someone can help me diagnose a couple vacuum line mysteries on my '88 Esprit. These are both located on the RH side of the car in the area above the rear wheel well. There's a lot of vacuum piping running around in this area.
1. The hose attached to port 2 of what I think is the EBP solenoid valve is not connected to anything on the other end. See pic...the line with the little red zip tie on it. From the diagram in the Service Notes it looks like port 2 just vents to atmospheric so this is probably OK. Sound right?
2. There's a very small diameter semi-rigid plastic pipe hanging down which isn't connected to anything. It looks like it runs forward up the RH roof channel, presumably attaching to something up front perhaps in the luggage area. I know there's some vacuum piping associated with the heater box (my heater isn't supplying heat), is this the vacuum supply line?
Any help is appreciated. Thanks.
