That's not how the logic modes work. L (advanced-logic) does not turn off X band. It ignores X hits unless the signal is strong enough for the detector to consider it a real alert, in which case it does so. l mode (logic) does the same, only instead of filtering low-power X hits, it alerts them at the mute volume. Both modes will go to full alert for X if the signal is strong enough.You just press the button in and it will go from lowercase L (xband off) to L (L ,K and Ka band on)
Correct. I was just keeping it simple and easy.That's not how the logic modes work. L (advanced-logic) does not turn off X band. It ignores X hits unless the signal is strong enough for the detector to consider it a real alert, in which case it does so. l mode (logic) does the same, only instead of filtering low-power X hits, it alerts them at the mute volume. Both modes will go to full alert for X if the signal is strong enough.
The only way you can turn bands on or off is via the programming menu. If you've turned off X band, there's no real reason to use either of the logic modes. Same goes for disabling K.
