1 - 7 of 7 Posts
I have 91Se,
looking at the couple of different parts cross reference lists out there I think I need a Wix 51085 or Fram ph43 oil filter, and for a fuel filter either fram G3727, wix 33481, or ac GF481. I just would like someone to verify this because the lists don't specify the different ones for 88, chargecooled, delco vs bosch, etc, they just lump the Stevens ones together. Any help would be great before I get them. Thanks
All the charge cooled Esprits use same spec oil and fuel.
Need oil filter with drain back valve. Most use Mobil 1-204 or K&N 2004 if not using a Lotus filter, some like the K&N due to the on filter nut which makes removal a little easier. Readily available as is the GM spec fuel filter.
Btw the same oil filter as used by the 4.0 liter Jeep Cherokee
The GF481 fuel filter is correct, but has been superseded by GF652.
Super Moderator
1 - 7 of 7 Posts
