1 - 13 of 13 Posts
I am getting a very bad smell from the vents when I turn on the air conditioning.
Has anyone else had this problem or found a solution?
I researched previous posts and the evaporator having condensation is my best guess as to the source. I store the car indoors in a temperature controlled garage (the only change is that I recently starting using an indoor cover). I was going to try and spray Lysol into the system but I am unable to find the vent/location where it pulls air from inside the cabin when in re circulate mode.
Any help is greatly appreciated.
spray lysol thru o/s vents while not on recirc.
5 minutes before you park, turn up fan and turn off a/c to dry it
Never use recirc.
www.theapexinn.com
Pepe Le Pew !
Don't use lysol.
Get some BG Frigi-Fresh. Check with your local BG dealer.
Lysol is usually the 1st step. If that doesn't do it, get BG.
I have the same smell. I'll try Lysol once my car's back. Does Frebreeze work too?
No, I think not. Lysol kills stuff, Febreze does not.
To mask the smell, I guess you could spray Febreze on cotton balls and stick them up your nose.rotfl
1 - 13 of 13 Posts
