For sale is a Tech-1 scan tool for use in diagnosing engine, driver's airbag and ABS brakes in 1989-1999 Lotus Esprit 4-cylinder cars and M100 Elans. Scan tool, cable and cartridges have all been tested for functionality. An original carrying case is also included as shown.
The scan tool is a genuine Vetronix Tech-1 in close to NEW condition, as specified by Lotus Cars for use in the above applications. The cable is a new, custom-built duplicate of the 15-to-10-pin ALDL cable T000T0897/2, which is no longer available from either Lotus or Vetronix.
The diagnostic cartridges included are as follows:
TK02370B – Esprit & Elan M100 ECM Plus (T000T0898/3)
Includes ECM (engine management) diagnostics for 4-cylinder Lotus Esprit cars equipped with Delco injection from 1989-1999 (both with and without chargecooler), as well as Elan M100 cars. Also used for SIR (airbag) diagnostics in cars with only a driver airbag.
Note: Even though the cartridge and menus only reference 89-90, Lotus used the same diagnostic cartridge for later model years, so if you're working on a 1995 S4s you would select 1990 as the model year.
TK02380 – Esprit ABS Brakes (T000T1115/1)
Includes ABS Brakes diagnostics for 4-cylinder Lotus Esprit cars equipped with the Delco Moraine ABS III system from 1991-1995.5.
Note: Even though the cartridge and menus only reference 91-92, Lotus used the same diagnostic cartridge for all model years, so if you're working on a '95 S4s you would select 1992 as the model year.
Shipping within the US is available at cost, please message me with a zip code for a quote. Thanks!
