Would like to start a nice central discussion thread for people installing these. The instructions included with the kit are pretty straight forward, but this can provide an area for users to discuss tips, tricks, etc.
*** Complete Installation was done by me on an 06 Exige with clam on ****
First off a parts check list
□ Assembled Supercharger
_ - MP62 Supercharger
_ - Drive Snout
_ - Inlet Mount (throttle body side)
_ - Outlet Mount (top side of supercharger)
_ - Outlet Mount to Intercooler Piping Adaptor (L shaped tube attached to outlet)
_ - Bypass Valve (the little "can" mounted on side)
□ Intake Manifold
□ Intercooler
□ Intake Pipe (polished aluminum with MAF sensor mount)
□ Air Filter
□ Pulley
_ - Stage I.....3.2" Part Number: ????
_ - Stage II... 3.0" Part Number: 58-90-06-031
_ - Stage III.. ????
□ Charcoal Canister Relocation Bracket (big black cage)
□ Alternator / Drive Snout Support Bracket (should also have 2 circle metal spacers + hardware)
□ Valve Cover PCV Flanges (2 milled aluminum pieces)
□ PCV Rubber Hose (big thick rubber hose)
□ VVT Milled Aluminum Adaptor
□ Dayco Serpentine Belt
□ Intake Manifold Gasket
□ Throttle Body Gasket
□ Vacuum Adaptors/Fittings/Hoses for Purge Valve Solenoid
□ RC Engineering Injectors
_ - Stage I. 440cc
_ - Stage II 550cc
_ - Stage III ????
□ Injector Wire Harnesses Pigtails (need 4)
□ Silicon Couplings With Hose Clamps For Piping
□ Replacement Oil Dipstick
□ Aluminum Coolant Bungs (2x)
□ Adjustable Supercharger Support Brackets (2x)
□ Various Baggies Of Nuts/Bolts (Ace Hardware usually has a good Metric selection)
□ ECU Shipment Info
□ Printed Instruction Manual (online color copy here)
□ Fuel Pump (Stage 2 & 3 Only)
*** Throttle body in kit picture is not included ***
_ - Drive Snout
□ Intake Manifold
□ Intercooler
□ Air Filter
□ Pulley
_ - Stage I. 440cc
_ - Stage II 550cc
_ - Stage III ????
□ ECU Shipment Info
