1 - 6 of 6 Posts
5-Element Railer (Jr.) Rear Diffuser for Lotus Elise & Exige
  • Direct OEM replacement for '05-'10 Elise and '06+ Exige
  • Comes WITH or WITHOUT exhaust hole cutout (Specify Below)
  • No drilling or modification required
  • 15 minute installation
  • Built from Aircraft-Grade Aluminum and Powdercoated Satin Black
  • Weighs only 10LBS (4.5KG)
  • Stronger and thicker than OEM to handle curb rash and track abuse
Diffuser body is 2 inches (5cm) longer than OEM undertray. Fins sit 5 inches (12.5cm) off the ground on stock suspension. Fins run parallel to the ground and extend forward to the undertray to channel air properly out the rear of the car. Fins are finished with squared off edges. This keeps air inside the fins and prevents air spill, reducing drag and improving downforce. This diffuser has slightly better performance than our 5-Element Rounded Rear Diffuser for Elise & Exige!
1268688
1 - 6 of 6 Posts
