1 - 3 of 3 Posts
I had noticed some marking on the front firewall where the pedal was hitting. Looking at the pedal box, the throttle pedal stop on the electronic throttle control valve was broken. This cracked the case and allowed the throttle pedal to travel too far. InoKinetic happened to have a used one on hand and three bolts and some help from another and it is fixed. If you see these marks on your fire wall the problem exists for you as well.
1264340
1264341
1264342
Yes, I listened to some videos and can hear it hitting the firewall. This may have been broken for a good amount of time. The used assembly bolted right in and is a GM part I believe Lotus is still using. One track day later and it held!
1 - 3 of 3 Posts
