1 - 8 of 8 Posts
for elise if you have torn out hvac pipes etc ,basically removed ac,I'm looking for the parts to put ac back in a previously tracked car that had components removed max budget 500
PM kfennell
I have a bunch of stuff, 80% probably. The only catch is that the compressor alone is worth most of that amount isnt it?
Off memory, I have the following:
Compressor
Hoses from compressor
Air drier and associated hose
One hose to condenser
Fan
The part that goes in front of the HVAC
The part that goes on the cabin side of the hose
Cabin ducts and even the main cabin distribution system
You would still need the main HVAC box, condenser and one hose, they typically sell for $700 ish more.
couple of AC boxes on ebay
Keinayo might have one
lines are pretty generic, I used Vintage Air cut to fit flex lines doing updates
Compressor, yeah, that might cost you some
which line kit did you use exactly if you can remember?i dont necessarily need the compressor at this point but hvac box etc i do
1 - 8 of 8 Posts
