1 - 17 of 17 Posts
Hey all,
I wouldn't even know where to try to start searching for such a similar thread so hopefully you guys won't flame me if this has been repeated. Recently on my drives... I've noticed that when I take a certain freeway interchange at a spirited speed, there is a brief flash of red from the dash. :shrug:
It only seems to happen when I'm aggressively driving. This is not a hard turn either.. it's a somewhat tight left hander, but again since it's the freeway it's nothing severe.
When I first encountered it, I thought it was the "brake" light warning coming on, but I could never have enough time to actually see which light it was. Has anyone else encountered such a problem where a warning light pops on during hard turns? :huh:
Thanks.
frequently reported:
here's one thread.
http://www.lotustalk.com/forums/showthread.php?t=32620
you brake fluid is low.
you may want to become a bit closer to your car... more familiar with the :tadts: stuff. brake pads. brake fluid. suspension bolts, tire wear, etc.
just a suggestion. certainly not intending to offend.
I agree with ace. You're likely going to need new pads very soon. If I were you I'd step away from the computer and check them immediately (check both sides because some have reported very uneven wear).
If those pad touch the discs, they're guaranteed to be shot. In fact, they likely need to be replaced anyway. IIRC, new discs are 24 mm thick, and when they reach 22 mm they are out of spec and are supposed to be replace for the bargain price of $400 each. :rolleyes:
On occasion mine has done has done the same thing. Fast left turn, brief brake warning light. It's happened (maybe) a half dozen times in two years. I'm convinced it's just an over sensitive master cylinder reservoir switch float. I've bled the brakes twice (once a year) and the car only has 6,000 miles on it, Brake fluid is never low and neither the pads nor rotors show much wear.
Randy
And to be specific (with absolutely no intention of being condescending), you need to check both sides of the brakes (inboard and outboard) not just both sides of the car. The outboard pads can look fine and the inboards can be down to the backing plate. Not a happy situation. :(
It happens because the res is orientated transverly (like the motor) and it was designed to be in line and the sensor (located in the cap) as a result is off to one side. At the proper level it will trigger the light in a hard left hander. Mine was overfull of fluid when I got it and the light did not come on. After flushing and filling to the proper line it started to come on a left hander. Obviously check pad wear, but I would say tadts unless you want to keep it slightly above full.
Ron
momentary brake warning light on left turns
I got rid of the symptom by filling the reservoir to the seam.
Besides the brake fluid level being low, some people have had "dirt" in the contacts in the cap that has also triggered the intermittent light. A cleaning of the cap has been known to cure it if the fluid level is up where it should be and you are getting the lights.
Another more remote possibility is that the switch on the parking brake lever is loose/maladjusted and is triggering the light under cornering. You can usually test this simply by wiggling the parking brake level around and seeing if you can trigger the light (although the switch could still be loose).
Bottom line is to check the fluid level first.
Then the cap.
Then the parking brake switch.
And oh, yea, there have been lots of threads about this already... ;)
Good point! I don't feel as though I've been condecended upon at all :wave:
For my car its my "seatbelt" light. I find that I have to move my seat to a certain position to stop it. There must be a sensor under the seat that is loose.
If the discs get scored, its ALOT more money to replace them...:shrug:
Yep, that's a very simple connection that you have to undo to take the seat out...can can forget to redo so your light never comes back on. :D
I guess i will be topping off my fluid right after i paid someone to do it:rolleyes:
Thanks guys. I was going to post this question today..
1 - 17 of 17 Posts
