1 - 7 of 7 Posts
Hi all,
My 05 Elise is having a weird issue , maybe I'm just stupid. As I put my foot down on the throttle I'd be loosing power, and it wasn't an consistent thing . After some playing around I thought maybe if I disconnect the vacuum line from my FPR I'd see a difference so I used my thumb to plug the vacuum line and opened the throttle body manually. Still , same issue . Then I for some reason decided to see what would happen if I let go with my thumb ( intentionally creating a vacuum leak) and it worked as it should. What could possibly be causing this issue and what should I do ?
Thank you in advance, Daniel
Sent from my Pixel 2 using Tapatalk
Is your car turbocharged?
Are you running a MAP based ECU?
Does it go lean when you initially hit the throttle but then get richer?
It is turbocharged . I'm running the EP tuning Standalone ecu from Elise Parts , on my 05. Yes it is . It's weird I'll look again in a few hours but it seemed to just go lean enough to die if I Don't catch it in time to let off the throttle . But I don't seem to remember the a/f r changing at least not anything significantly . Also I have a water meth kit installed. Same issues with it on or off
Well, being boosted with a standalone is good info if you actually want any decent input, haha
It sounds like a tune issue. Has the car ever ran right in its current configuration? If so, what changed between now and then?
Less is Better
Agreed, Kind of important to know that it's not stock!
I would also agree that I'd be looking at tuning first. @dan2468 can you get real time data from the ECU? That's the best way to diagnose this.
Lol , thank you Caleb and me73 , if I were smarter I would've thought of that . I've done so much to this car .
You guys were right it was the tune , I was an idiot , I had the wrong map selected . It's running fine now .
Thanks guys , sorry for the waste of time
No worries! Glad it was that simple
1 - 7 of 7 Posts
