1 - 15 of 15 Posts
I have a slight tire rubbing sound when hitting a bump while turning hard right. I think it's just due to wider tires hitting the mud flap, but took a look inside and all I noticed off was the below, all three clips attaching, what I assume is the abs sensor cable to the brake line are broken and became detached (you can't tell from the pic , but when I try to reattach them, it's obvious the wider side is cracked and won't hold. The car is an '05 with 19k miles and the same part on the other side is in perfect shape. A few questions:
- Does anyone know the part name or number and where to best buy a replacement?
- Should I buy replacements, use zip ties, or ignore?
- Is this a problem itself, or symptom of something I should be concerned about?
Thanks in advance for the help.
Fat Guy In A Tiny Car
Honestly, I can't tell from your photo what exactly you are talking about. However, if you go to lotusgarage.com, you'll find diagrams and parts for the entire car according to category and location. I would check there.
lotusgarage is very useful, but didn't work for me in this case as I didn't see that part listed under brakes (maybe I'm looking under the wrong sub-system). In the pic, I'm talking about the 2 clips that you see connecting maybe the main brake line to the parking brake line. One of the clips is just below the white tag in the center of the frame with the upside-down "R" printed on it. The clips have 2 sides, a smaller diameter that connects to one of the lines and a large diameter that connects to the other.
Sounds like a job for zipties to be honest.
Thanks for the clarification. I think what you're looking at is part numbers 32 and 33 in the attached diagram. Here's a link:
https://www.lotusgarage.com/index.php?pg=4&l=product_list&c=110
Just to clarify, all of the parts I mentioned are basically small zip ties with nodules on them that allow the plastic clips to lock on to them.
These are not zip ties, nor attached to anything zip tie like. They are hard plastic clips and not like what's shown in the lotusgarage illustration I considered just replacing with zip ties, but was worried it might crimp the line as the clips grab the protective spring while a zip tie would reach through the spring and grab the rubber line itself.
Addict
2007 Lotus Exige S
You could buy a length of fuel line or coolant hose and slice it to go over the protective spring and zip tie around that. I have not been able to find those clips in the right sizes, so if you do please post a source.
My clips were cracked too. After some thought, they will become just as fragile and break again. Especially if you unclip and clip them back on when doing work in the area. Decided to just zip tie it and never have to worry. Probably last longer if not forever, and cheap to replace if I ever need to undo them.
I wish you had put an arrow or something on your original photo. Are you talking about part number 25 on the illustration?
What you are looking at appears to be your left front suspension but I could be wrong.
Explain to me what in that picture is rubbing the wheel? Even though those clips are broke the lines are trained the position they were when put on. They should stay there and still not touch the wheel. Thus the chaff guard on them. If they are rubbing the wheel look at it an find rub marks on the inside of the rim or tire.
Did you put bigger tires on and are rubbing the wheel well liners? Common.
Discussion Starter #13
After looking at it, I don't think the rubbing is related, just something I noticed when trying to find the source of the rubbing. The rubbing is almost certainly just the wider tires.
Curious, what wheels and size tires you running?
1 - 15 of 15 Posts
