1 - 20 of 23 Posts
Amazon.com: Skil 2372-01 7.2-Volt Li-Ion Power Wrench: Home Improvement
Looks kind of cheap, but I can't find something similar in a higher end brand. Think it can do the 12 or so diffuser bolts in a single charge? I think I nearly got carpal tunnel last oil change. I dont have air tools (nor do I want them) and I am afraid one of the manlier impacts may be a bit too much for those tiny guys.......
Super Moderator
That one would probably work OK, but I use this one: Amazon.com: Skil 2336-01 3.6-Volt Mini-Drill/Driver: Home Improvement I actually purchased it to remove/install all the screws for the inspection panels and interior parts that need to be removed from my airplane every year for its annual inspection. I later found it works great for the undertray/diffuser, because it fits in the palm of your hand and gives you the clearance to the floor to allow you to zip out the screws easily. I have air tools as well, but I find this little driver to be much easier and faster to use.
BTW: The price shown on Amazon for this driver can easily be beat at your local home improvement store.
I have this tool you listed. It works great. I don't have the 1/4 turn diffuser bolts, so this really helps out. Removes all of them and installs them easy with 1 charge. Prob could do it a few times.
I don't plan on changing to 1/4 bolts, so this works well for me, not to mention many other useful purposes for it around the house.
If you're not doing 1/4 bolts, then this is a usable solution, and the advantage over air tools, is there is no hose, and it's easy to use.
Cheers,
Skottoman
Awsome thanks for the tips guys. I think Ill order the skill tool. The 1/4 turn fastener kit looks nice too but Ill stick to stock for now. I did see there is a ingersol rand electric socket as well. It looks like a nice tool but is 150 with no Batteries. I like to buy better tools these days but I think that is over kill.
Once you use the quarter turn fasteners you would never go back to the old way! Dropped the panel this morning in under 2 minutes!
Jerry
i use a black/decker electric screw driver, the pistol grip one that looks liek a squirt gun - i wanna say it was like 40 bux at lowes or target or walmart or wherever i got it.
i like it because the torque is "hand tight" so works perfect - not too powerfull, not too weak - just right.
air tools.
I used an electric screwdriver too before I got the 1/4 turn fasteners and it worked very well. Actually, compared to the electric screwdriver, the 1/4 turn fasteners only save a couple of minutes, but I think they're a more elegant solution. :)
+1:up:
Discussion Starter #15
Discussion Starter #17
Air tools are for cheaters and girly men with no arm strength! On a completely unrelated note I have no room for a decent compressor in my garage.
And air tools have hoses. Wireless is the new way to go in the 21st century! Just looks what they were able to do with PHONES! WIRELESS! :D
Cheers,
Skottoman
But air tools make life so much easier. But I'm old school and like hand tools. Nothing beats the [email protected]#$ you bar for those pesky bolts.
Air tools for removal only never install in my book.
1 - 20 of 23 Posts
