1 - 9 of 9 Posts
The oil line recall calls for the front clam to be removed. What else should be checked/fixed on an 05 elise?
1. Replace Radiator and fluid
2. Replace radiator hoses
3. Replace oil cooler hoses
4. Replace both fans
5. Replace all fuses
6. Disconnect and reconnect all ABS lines
7. Change both front A arms components
8. Rotate tires
This should keep you busy for a while, check back with me after you're done :D
Take a look at your front turn signals from the inside - make sure they are on there tight.
Absolute power does what?
Stainless steel braided brake lines (if you're gonna track it)
1 - 9 of 9 Posts
