1 - 12 of 12 Posts
I dynoed my 2011 S1 (13K miles) in pure stock form except for cooling radiator added in rear, underneath the engine) on a Hunter dyno yesterday with temps in the 40s. The best of 3 runs was 294.58 hp. Is this pretty much in line with other dynoes of S1s? I plan to add headers, CAI and tune. Not sure about a larger crank pulley, but I don't believe I will install a smaller s/c pulley. What do you suggest?
Illegal Alien
search my name for some dyne plots from 2014-2016 .. 294 @6100 rpm and Tmax 279 ft-lbs @ 4300 rpm was my baseline. I would not recommend changing pulley sizes, a) going to larger crank will eliminate the harmonic balancer within the stock pulley, and b) increasing SC rpm by larger crank or smaller sc pulley will push teh SC even further past optimal thermal efficiency, raising even more heat after than more boost. Lotus didn't go to a larger SC on the 400's for no reason.
Sounds about right if you assume 15% drivetrain loss. What do you mean by "cooling radiator added in rear"?
sounds about right. I did a CAI from BOE and a Plack exhaust. best pull was 314 whp. that would equate to 368 crank HP so i am pleased. The car does feel a little quicker so it was a good investment for me. not sure about the stage 2 stuff for me but yes it can be 15% or more is about right. I am sure some will chime in that it is less but everything I see and read is 15% or more loss to the wheels.
2011 Evora NA 6sp
About 420 whp
Edit: 2011 Evora with BOE TVS1900 supercharger. This was with stock NA clutch, flywheel and trans.
1257931
2011 Evora NA 6sp
???? what am I missing? is this a mod Evora S or a 400 with mods?
2011 Evora. Started NA. Has the BOE tvs1900 supercharger kit.
Maniacal Motorist
You're skewing the poll, haha!
I'd really like to get my tune so I can appreciate the transformation. I had an issue downloading the firmware to the ECU. All I need is that and my tune file. Oh, and the headers back from Swain.
is the eh
Is the header install a big deal or a simple mod????
Here's a thread on it...
Maniacal Motorist
The BOE headers are supposed to go on pretty easily. I currently have the rear clam off, but it will likely be back in place before the install.
1 - 12 of 12 Posts
