1 - 10 of 10 Posts
Hi all! Decided to do some [first time for me] routine maintenance over the holiday weekend. After removing the undertray, I came to find this aftermarket oil pan. I'm now questioning the impact this has on oil capacity and trying to identify which model it is. Haven't been able to locate this exact one from the searches I've done thus far. Anyone recognize it?
Cheers and appreciate the help.
Administrator
2005 Lotus Elise
** The Enforcer **
When you change the oil, make sure to insert a long tool into the oil pan drain to open the trap door inside the oil pan, this will let all the old oil to drain from the oil pan.
It will let a lot more oil out of your oil pan, but if you have the stock oil cooler(s) in front and the long lines you'll still have a lot of old oil in your system. That is a nice tip though, and I don't remember seeing that posted. :up:
San
2005 Elise LSS Saffron Yellow
One of the reasons I bypassed the stock cooler setup (I have an '05 with the 'Persian Gulf' dual front coolers package) was to get cleaner oil changes. I already removed about a pound of oil from the car by blowing out the coolers and lines. Once I get them removed the car will be simpler and lighter still.
2007 Exige S
I see your black plastic flywheel dust cover is not installed. I just installed the moroso pan and either forget to put that in first or it just ain't gonna fit now.
A bit of googling and I see a DD Performance makes a stainless bolt on that looks decent. Went to buy one, but on back order.
Thoughts from the forum as to its importance and options for a piece that fits with the moroso pan?
Thanks, Mike
1 - 10 of 10 Posts
