1 - 20 of 24 Posts
Hardtop or soft top? I know it depends on who you're running with but the pre tech never said anything about it.
The softop has more headroom, and possibly better visability.
Any takers?
Better visibility with the soft top? Not a chance.
Safer with the hard top? I would think so, the more "hard stuff" around you the better debris protection you have. That being said, use the hard-top.
That, and it'll be less drag on the car anyway.... and less wear on the soft-top. Do you know how expensive those things are? If some track "whatever" hits it, it'll cost you more than some simple fibreglass repairs and paint work...
Neither make the car safer, non is part of the loadbearing structure, eitherone work as well as open roof.
How about no top at all, if they let you? Seriously, if you have an accident, neither top is doing you any favors as they will fly apart.
2008 Exige S240
The soft top weights 10lbs.
The hardtop weights 25lbs.
questions?
Failed at Self Control
I've been going with the hard top on and haven't regretted it once. Even when it was pushing 110 degrees I think the hard top was a good idea. I wasn't tracking to shave seconds off my time and was really just learning the lines and basics so I even ran the AC. I was staying nice and cool and the car didn't seemed phased by it at all. ...at least not at the level that I would notice ...being the noobie that I am.
I vote for leaving the hard top 'on'.
- z
2008 Exige S240
The hardtop doesn't weight 25lbs. It's closer to 12 or 13lbs...
have you ever weighed it?
The hardtop w/finisher piece weights 25lbs.
If you don't know the answer to something, don't guess,
it makes you look foolish.
Damn I guess for someone giving out advice about being foolish... you might want to try a more tactful way of saying it?
Not the admin anymore
I used to track mine topless. :rolleyes:
Any problems with nipple chaffing?
(sorry couldn't resist)
Spec Miata requires a hard top. Different car, certainly, but knowing why a spec series would require a hard top for cars with cage protection might be instructive. Also, the Bay Area BMW club requires hard tops on any Elises that do their track schools. I can ask them why and get back to ya'll.
FWIW, BMWCCA requires hard top.
And one of their regional chief instructors is trying to get that rescinded.
Only reason to have either top on the Elise is weather protection. Hardtop probably contributes some chassis stiffness, but not so much that it makes a significant difference to most of us.
Unless one has arm restraints, having a top on could actually be a negative in the event the car went on its lid. If someone's arm flew out under extreme circumstances (going turtle is a pretty extreme circumstance after all) it could be seriously injured or even severed.
Right up until the point (during rollover) your hands and arms flail out of an open roof ....... :eek: Although neither offers any real impact protection, both will help keep your limbs inside the vehicle, so you should use one or the other on track.
If you're using a net or restraints.
I'm over it.
I don't have a scale, but it sure as heck doesn't feel like 25lbs.
I vote topless...
<img src="http://www.elisetalk.com/gallery/files//6738-img_0934ar.jpg" alt="Beaver Run May 2008" />
1 - 20 of 24 Posts
